Is this the right way to do two-sided CAM?
I spent a couple hours this afternoon trying to figure out how to set up two-sided machining, and I think I've gotten to a point where if I were to run the job in some stock, it would pop out a completed part.
So, let me know if this is a "correct" method:
1. Create two CAM setups, with identical stock. For the top of the stock, set the origin wherever you want the origin to be. Then flip the model over the same way it will be flipped on the CNC machine, and put the origin in the same location on the second CAM setup. So for me, I put the origin at the bottom left corner of the stock, using a stock point. When I flip the stock over (like reading a book...side to side, not top to bottom) I put the origin in the same location...bottom left corner.
2. Create toolpaths under the corresponding CAM setups. In my test run, I did a pocket clearing for both. So on the bottom, the toolpath will essentially mirror what happened on the top.
2a. Set the correct bottom height!! This was the key for me. I tried using the origin, but it gave me an error, so I offset the bottom height to put it in the middle of the stock. In my test project, the model is 6mm thick, so I offset the bottom height by 3mm, for both pocket clearings. (And for any other toolpath I'll generate)
3. (Haven't done this part yet) Post process. I'd assume you'd want to go in and edit the G-code, so that you put an M0 between each pocket clearing so you know when to flip your stock over.
Things I haven't done yet, but I probaby should:
1. Add fixture location to the stock. I just put some MDF over the t-table on my machine today, because I wanted to have a consistent place to mount stock for projects. I figure it wouldn't be a bad idea to add this fixture point to any project, so the machine knows not to run into any screw/wingnut that might be sticking up.
2. I had something else I think, but I forgot. So...any suggestions for what consists of good practice when doing two-sided machining?
Overall, does this process seem sound to the experts? Am I missing anything? If you want to take a look at the test run I did, I'd be happy to post the file.
