Engraving center of text
Message 1 of 10
I've managed to get the engrave function to work ok, but it seems to want to trace around the characters. Is there a way engrave in the center of the character either with the engraving tool or with a small ball endmill? The tracing around the outside is not as easy to read for something like a part number etched into a part. It's also slow.
Thanks in advance.
Replies (9)
Message 2 of 10
Steinwerks
Can you share an exported .f3d of the model, or a dummy model exhibiting the same problems?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 10
Here's a copy of the model as well as a picture of how it cut. I'm just not sure if tracing around the letter like that is my only option at this time, or what. Maybe it's the best I can hope for until we can engrave with a ball endmill to trace out the center line of the letters. Or maybe I'm doing it wrong!
Message 4 of 10
HughesTooling
What you're after is single line engraving, at the moment there is no built in function to draw single line fonts. You can import something as DXF of SVG and use trace, that's about the only work around.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 10
Sounds good. I just wanted to make sure I want missing something. Thanks!
Message 6 of 10
HughesTooling
I was just experimenting with some stick fonts available here. The numbers worked quit well, a few missing lines from the letters. Wouldn't take much work to put right.
Mark
Mark Hughes
Message 7 of 10
MattWynn
yes. Single line fonts are really important.  We need to mark plain text on parts and we need it to be fast, really fast.
Enentually we need to be able to support machines that can machine the text automatically given the letters.
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
Message 8 of 10
That's what I need. Simple part number, fast with a small ball end mill. The engraving cutter is too slow for production.
Message 9 of 10
Steinwerks
You can also use a 2D Contour and turn off Compensation Type which will use arcs and smoothing. Did this for some line engraving last week.
Neal Stein
Find me on:
Message 10 of 10
antmob
Has there been any updates on the ability to create single line text and engrave on center? Seems like an easy fix considering all the advanced features they have been adding to the software. Also, I've noticed that when engravinging text, the toolpath that is created is not very efficient. It will sometimes start engraving letters towards the end of the word instead of starting at the first letter and continuing sequentially. This issue will cost a lot of time when trying to engrave large quantities of parts.
thanks in advance for any input!
