Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Work from last couple of days disappeared
melfio
melfio
I've been working on a project for the last couple of days, FUsion 360 has been crashing pretty regularly so I've taken the habit of saving like every five minutes or so.
However, at the last crash there was no recovery document created, instead, one file I've been working on has completely disappeared and the other has been restored to its state a few days ago.
I've had internet connection almost all the time working with these files..
Is there any way for me to recover the last saved files from my computer?
Steinwerks
Have you tried expanding the file options and seeing which versions are available?
Also if the software is crashing so regularly, I would highly recommend contacting support directly tomorrow morning.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
HughesTooling
Try changing to offline mode, if the file's available in the data manager in offline mode open it make a local copy using Export from the file menu and use Save As and save with a different name, go back on line and see if the new file has saved.
Mark
Mark Hughes
Owner, Hughes Tooling
melfio
Brilliant, that solved it. Thanks!
