- Mute
- Permalink
- Report
I would like to engrave a logo in wood with a vee tool. I want the tool path to increase the depth of cut in order to increase the width as required to achieve the shape.
For example: a curved line that is wider in the middle then at the ends. The tool would plunge deeper in order to reach the width as it changes.
I was going to use a flat end mill to carve out the shape but some profiles are 0.020" wide or less. It's impractical to use a flat end mill.
I never run into this type of feature in metal on the mills - where all my experience is. This is just a woodworking project for family. I understand this is a simple feature for most woodworking softwares, I am unsure of what tool path to use in Fusion.
I will try to post a picture of the logo for reference.
