Something has changed and I can't figure out what I'm missing
I'm using GRBL as a post processor
When each of my milling jobs are done, the tool rises to the clearance height, moves +X and +Y
I haven't looked at the code as I figure this must be a setting somewhere
It is meant to do that, its basically a safety move so it can move in X and Y and not hit anything, then if you want you can move it in X, Y, or Z yourself.
What has the box around it is doing it.
Info about G28
https://www.cncci.com/post/how-the-heck-does-g28-work
If you do not what it to happen you need to change it to a Z move do not remove G28 without replacing it with a Z move you will learn fast why the Z move is needed if you just remove the G28.
