In using fusion 360 at work and am very new to it. I'm trying to program a basic radial contour using cutter comp "in control" as programmed, but whenever it gets to that line of code in the program, the machine stops and an error reads "cannot compute path". I can program it with comp in computer no problem, but I'd like to be able to make adjustments at the machine. Anyone have any ideas?
You may have to use "Wear" or "Inverse Wear" style compensation. Give wear a try and see if that produces a controller error.
