I'm trying to figure out if there is a way for Fusion to detect collisions between a dust boot and the stock. While I have specified the geometry of each bit and the tool holder, I can't seem to find a mechanism to allow Fusion to be aware of the geometry of the dust collection system surrounding the bit + tool holder. My concern is primarily with 3D tool paths (3d adaptive) with steep slopes (high peak adjacent to low valley). I considered creating a custom tool holder incorporating both the actual ISO30 holder with a model of our dust boot, however it seems that the custom models are circular and our boot is rectangular. Any insights or alternatives would be appreciated, thanks!
Solved by seth.madore. Go to Solution.
Are you using Machine Simulation and have the boot included in the machine model?
I am using simulation to validate tool paths, however the boot is not incorporated in the model. I'm currently only aware of how to specify the tool geometry and tool holder.
I'm now seeing the "Simulate with Machine" option, however our mill is not in the machine library. Would the approach from here to modify a generic machine to match our setup?
Yes, that's what I would advise. Here are a couple resources for you to consider:
https://www.youtube.com/watch?v=XYD1EMOh3WY&t=18s
https://www.youtube.com/watch?v=84Afm8nlKTs&t=5s
