Fusion Manufacture
Doosan Lynx 2100LSYB turning while spindles synchronized
4 REPLIES 4
warnerwerkswv
362 Views, 4 Replies
I have a part where I need to grab it with the sub to support it, and turn it, and I'm getting an error because it can't command a spindle start when the spindles are synced.
Is there a workaround or a different way to do this?
4 REPLIES 4
@LibertyMachine @seth.madore any input on this?
Where are you getting the error? At the machine or when posting code?
The onParameter function shows some Actions that should be used.
function onParameter(name, value) {
  var invalid = false;
  switch (name) {
  case "action":
    if (String(value).toUpperCase() == "PARTEJECT") {
      ejectRoutine = true;
    } else if (String(value).toUpperCase() == "USEXZCMODE") {
      forceXZCMode = true;
      forcePolarMode = false;
    } else if (String(value).toUpperCase() == "USEPOLARMODE") {
      forcePolarMode = true;
      forceXZCMode = false;
    } else {
      var sText1 = String(value);
      var sText2 = new Array();
      sText2 = sText1.split(":");
      if (sText2.length != 2) {
        error(localize("Invalid action command: ") + value);
        return;
      if (sText2[0].toUpperCase() == "TRANSFERTYPE") {
        transferType = parseToggle(sText2[1], "PHASE", "SPEED");
        if (transferType == undefined) {
          error(localize("TransferType must be Phase or Speed"));
          return;
      } else if (sText2[0].toUpperCase() == "TRANSFERUSETORQUE") {
        transferUseTorque = parseToggle(sText2[1], "YES", "NO");
        if (transferUseTorque == undefined) {
          invalid = true;
      } else if (sText2[0].toUpperCase() == "USETAILSTOCK") {
        forceTailStock = parseToggle(sText2[1], "YES", "NO");
        if (forceTailStock == undefined) {
          invalid = true;
      } else if (sText2[0].toUpperCase() == "SYNCSPINDLESTART") {
        syncStartMethod = parseToggle(sText2[1], "ERROR", "UNCLAMP", "SPEED");
        if (syncStartMethod == undefined) {
          invalid = true;
      } else {
        invalid = true;
  if (invalid) {
    error(localize("Invalid action parameter: ") + sText2[0] + ":" + sText2[1]);
    return;
any Update on this error?
I am getting the same error message when I try and turn between synchronized chucks after a subspindle grab operation.  My roughing operations output properly, but my finishing operation errors out.
If you are using the latest post from the library, there are now some Manual NC commands that you need to use:
syncSpindleStart:error, unclamp, speed   - Method to use when starting the spindle while they are connected/synched
You would put: "syncSpindleStart:speed" for turning operations.
Seth Madore
