Hey, there all I googled how to get custom CNC machines into Fusion 360 and haven't found a lot of useful information on how to get my DIY CNC into fusion 360 and test it to see if it's working.
I got everything moving in Mach3Mill I just don't know how to get the other two axes A and B working with my design in Fusion 360.
I'm sure getting my reference model into Fusion should be easy I don't know how to get the cutting action to work with my machine. I'm not worried about getting my reference model into fusion, I need to know how to get movement cutting actions like rotations of axis A and B included in relation to how my machine moves.
Solved by engineguy. Go to Solution.
Solved by DarthBane55. Go to Solution.
Solved by johnswetz1982. Go to Solution.
I hope I didn't ask for the imposable or do I need to ask again in another post?
Also, I learned you can't remove or delete comments or posts (not that I want to delete this post I really need help with this).
It's not 100% clear to me, but really what you want is program a toolpath that will rotate the rotary axis of your very cool home made machine!
The machine will not move inside Fusion. So when you do a toolpath that is at an angle, you need to go in the operation and set the tool orientation to the angle you want to machine. You can set that in the "geometry" tab, there is a check box for "tool orientation". Be mindful of the X-Y orientation, it can be confusing at 1st, but, if I look at your machine, you would pick the Z axis perpendicular to the face you want to machine, and maybe the Y axis pick the back of your machine table. That should orient the axis correctly.
I hope this is sort of what you were after... if so great, and post back the results, I find your machine very interesting!
@Anonymous
Not exactly sure what you mean by "Get the CNC Machine into Fusion", as you have Mach3 I am assuming that you are OK with setting Part and Tool offsets already.
All you need is a Post Processor for Mach3 that will post the correct code for 5 axis movement, in your images I see it is a pretty standard Trunnion setup, in which the attached Post Processor will do the job for you.
The standard for the Trunnion setup is usually A and C axis so setup your Mach3 that way as that is what the PP is configured for.
Stay Safe
Regards
Rob
@Anonymous wrote:Yes, I think thats what I want to do. now, how do I do that.
hmmmm, I thought I explained how to do it... how else could I help you? You check the box for tool orientation, pick the axis, and that's it. I might be overlooking something in the steps tho, but did you try that? What steps would you be missing to do your toolpath at the correct angle? If you struggle with something specific, could you upload a snapshot of the situation?
You dont want multi axis for that. 2D contour with tool orientation turned on. Not sure how big the part is and your tooling so you may not even be able to cut it if it is too big.
Just so we get an idea of exactly how much we need to explain, is this your 1st project in Fusion, or are you a seasoned user for 3-axis use?
I'm seasoned with a large 3-axis shopbot I can make that thing do anything within its power and good at Solidworks, Maya, C4d, and lots of experience 3d printing. I can get this CNC machine i created to do anything i want 3-axis related. but I'm stuck on the 4th and 5th axis. Sorry about being new to Fusion Manufacture and its toolsets.
Hahaha, don't be sorry!! We all been new in Fusion one day. However, for me, this is gonna turn into a "Fusion manufacturing 101" class and it is too involved for the little time I have to check this forum. So I will step out.
However I can recommend you go thru the usual learning process of a new software by going thru some tutorials in the help, and some really great YouTube channels explaining how to get started with Fusion. I think this would be a really good start to get you going thru the steps of making programs in Fusion. Sorry I can't be of more help. Maybe someone else can jump in here.
Have fun with Fusion, you'll love it once you are used to it!
PS: https://www.youtube.com/watch?v=Bd6-BQUCbVA&ab_channel=LarsChristensen
this guy makes awesome tutorial videos, have a look.
@Anonymous
Well, looking at your example as has already been posted that is a simple 3 axis 3D operation, rough some material out and finish with say a Parallel just as an example.
If you want to do something on the sides of the block then model whatever it is say a pocket, drilled holes etc and use the "Tool Orientation" facility to get the toolpaths, then it is the usual generate the code and good to go 🙂 🙂
It doesn`t match the size of your trunnion but you should get the idea, just one I had in stock, it is basically doing 4th axis indexing, just an example of simple stuff 🙂
Try out the attached file, run the simulation and then find a Post Processor to suit your CNC Machine Control with 5 axis ability.
Stay Safe
Regards
Rob
I got an error when I tried to use your Mach3Mill.cps and Trunnio-Test wonder what I'm doing wrong.
Thanks for all your help this far. 😄
Information: Configuration: Mach3Mill
Information: Vendor: Artsoft
Information: Posting intermediate data to 'FileLocation'
Error: Failed to post process. See below for details.
Code page changed to
Start time: Thursday,
Post processor engine: Vertion
Configuration path: Path
Include paths: Path
Configuration modification date: Thursday, November 12, 2020 9:35:21 PM
Output path: FileLocation
Checksum of intermediate NC data:
Checksum of configuration:
Vendor url: http://web.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.9313
Error: Retract option 'Clearance Height' is not supported for multi-axis machining.
Error at line: 1816
Error in operation: 'Adaptive1'
Failed while processing onSection() for record 442.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error at line: 1816
Error: Failed to invoke function 'onClose'.
Error: Failed to invoke 'onClose' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, November 12, 2020 9:35:49 PM
Post processing failed.
Here is what's happening on my end. I recommend watching this on youtube, it randomly stops playing on here for me.
@Anonymous
Oops, Doh, sent you the wrong PP, try the attached file and PP 🙂 🙂
Stay Safe
Regards
Rob
@Anonymous
Well, all I can say it is working fine here, did you try out the Trunnion Test file using the modified Post Processor I uploaded on my last post, they work here, attached is the G Code as generated here using the Trunnion Test f3d file and the 5 Axis Post Processor, not anything else I can do from here if your machine won`t run the attached code file 😞 😞
Stay Safe
Regards
Rob
Does it have something to do with the machine type i created this but I don't know if i configured it correctly or how to set it up?
Here is My Mach3Mill_5-Axis.machine script
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<machine xmlns="http://www.hsmworks.com/xml/2009/machine">
<vendor>Autodesk</vendor>
<model>v1</model>
<description>Mach3Mill 5-Axis</description>
<control></control>
<fusion>
<model></model>
</fusion>
<machining additive="no" jet="no" milling="yes" turning="yes"/>
<dimensions depth="0mm" height="0mm" weight="0kg" width="0mm"/>
<capacities depth="0mm" height="0mm" weight="0kg" width="0mm"/>
<png128></png128>
<mtk></mtk>
<custom>
<name></name>
<softwareVersion></softwareVersion>
<network ip="" port="" protocol=""/>
<serial></serial>
</custom>
<coolant options="FLOOD"/>
<multiAxis adjust="yes" angle="10deg" cone="3deg" feedRateType="inverse" linearizationTolerance="0.040000000000000001mm" method="off" reconfigure="yes" tolerance="0.040000000000000001mm"/>
<tooling maximumToolDiameter="0mm" maximumToolLength="0mm" maximumToolWeight="0kg" numberOfTools="100" toolChanger="yes" toolPreload="yes"/>
<machiningTime ratio="1" toolChangeTime="15s"/>
<capabilities maximumBlockProcessingSpeed="0" maximumFeedrate="0mm/min" workOffsets="100"/>
<simulation retractOnIndexing="yes" shortestAngularRotation="yes" wcs="0mm 0mm 0mm">
<machineAssembly></machineAssembly>
</simulation>
<post>
<postProcessor></postProcessor>
<postProperties>
<Parameters/>
</postProperties>
<setupSheet></setupSheet>
<setupSheetProperties/>
</post>
<axis actuator="linear" coordinate="X" homePosition="0mm" id="X" link="table" maximumFeed="0mm/min" name="" offset="0mm 0mm 0mm" range="0mm 0mm" rapidFeed="0mm/min" resolution="0mm"/>
<axis actuator="linear" coordinate="Y" homePosition="0mm" id="Y" link="table" maximumFeed="0mm/min" name="" offset="0mm 0mm 0mm" range="0mm 0mm" rapidFeed="0mm/min" resolution="0mm"/>
<axis actuator="linear" coordinate="Z" homePosition="0mm" id="Z" link="table" maximumFeed="0mm/min" name="" offset="0mm 0mm 0mm" range="0mm 0mm" rapidFeed="0mm/min" resolution="0mm"/>
<axis actuator="rotational" axis="1 0 0" coordinate="X" cyclic="no" homePosition="0deg" id="U" link="head" maximumFeed="21600deg/min" name="" offset="0mm 0mm 0mm" preference="dont care" range="0deg 360deg" rapidFeed="0deg/min" resolution="0deg" tcp="yes"/>
<axis actuator="rotational" axis="0 0 1" coordinate="Y" cyclic="no" homePosition="0deg" id="V" link="head" maximumFeed="21600deg/min" name="" offset="0mm 0mm 0mm" preference="dont care" range="0deg 360deg" rapidFeed="0deg/min" resolution="0deg" tcp="yes"/>
<spindle axis="0 0 1" maximumSpeed="0rpm" minimumSpeed="0rpm">
<description></description>
</spindle>
</machine>
@Anonymous
You do seem to be making life hard for yourself, you don`t need a Machine Configuration for it to work, I don`t have one in the Trunnion Test file which you should have seen if you checked the Setup in Manufacture, it works fine generating the code. Setup image below.
Have you tried actually loading the G code I sent you into your machine controller ?? Does it load and run without error ??
Stay Safe
Regards
Rob
