Hello, I'm having a bit of an issue when trying design and create toolpaths on sheet metal parts to be plasma cut. Using Fusion 360 for Personal use. To create bend reliefs along the bend (to make bending by hand possible) I am trying to disable the lead in feature. Even with unchecking the lead in feature when setting up the toolpath, lead ins still appear in the program. Just looking to have the toolpath pierce and cut the straight line. I'll attach the file in case I am just missing something simple. Thanks!
Solved by jhackney1972. Go to Solution.
Here you go, specify the Lead In and set it to "0". I checked "Keep Nozzle Down" but that is up to you. Model is attached. If this answers your question, please "Accept Solution".
John Hackney, Retired
