Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Difference between swarf's single pass and trim from top
0 REPLIES 0
Message 1 of 1
ltomuta
152 Views, 0 Replies
I need to swarf a slot and I'm trying to do so incrementally, in order not to load the small tool. Looks like I can do this with cutting mode "trim from top". But, unlike when I use single pass, the simulations seem to show that in this case the tool does not go as deep axially.
With single pass:
With trim from top - ball end mill's tip does not "scratch" the model, only the side cuts.
As I cannot do a section analysis on the simulation, I cannot see if there is really material left there or is this just a simulation artefact. What would you say it happens here?
0 REPLIES 0
