I'm new to fusion but have a little bit of experience with some other 3d programs.
I have the STEP files of a truck bed that I want to use as reference to build something that will fit in it. How can I load those step files and use specific faces as reference points to build a sheet metal enclosure? I can't seem to find any tutorials like that.
Solved by DarthBane55. Go to Solution.
Just so you know, you are in the manufacturing forum, you would probably have better luck posting here:
https://forums.autodesk.com/t5/fusion-360-design-validate/bd-p/124
