When you select a cutting preset for a tool using the tool manger the preset does not apply. This might be a bug or my misunderstanding of this feature.
Solved by jhackney1972. Go to Solution.
Take a look at the video for the process of using the Cutting Data tables.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Ah this is perfect. I was confused about where these presets were going and what I needed to do to apply them. I was trying to go to tool manager and thought that I need to set the tools to be used with a preset for all operations. But I needed to go to my operations and select the preset from either that dropdown or like you had described go to the tool cutting data from the operation. This makes sense thank you so much.
I also completely did not expect a full video explanation I applaud you for putting in that massive effort.
