Hi. We want to purchase 4 axis CNC similar to this one:
Jinan Acctek 4 axis cnc router machine AKM1525 (youtube.com)
But in fusion option there is no 4 axis machining. Only 3 and 5 axis.
How to make constrain to only 4 axis?
Hello @d.konopko . Apologies for the late reply.
As you may have found already by now, some strategies do offer the 4-axis Machining Type, e.g. Geodesic and Deburr. Some are intrinsically 4-axis, e.g. Rotary Pocket, Rotary Parallel, and Rotary Contour. Perhaps these can be of use to you?
We are working to make 4-axis machining easier in other strategies. Until then you can define the tool axis limits to restrict the cutting moves to 4-axis motion only. For example:
If you require Collision Avoidance, set that "To curve" too, selecting the same sketch.
Hope that helps.
