CNC skips steps along the Z axis.
thekondrat
thekondrat
Hi everyone.
I have problem with my simple 3 axis CNC with stepper motors and Fusion360.
I use simple comand 2D Pocket.
While working my CNC skips steps along the  Z axis.
The problem occurs when the milling cutter completes the operation in one pocket and begins to move to another pocket, a sharp jerk up occurs and the machine skips a step.
As a result, the first pocket has a depth of 5.7mm and the second pocket 6.0mm.
If there are a lot of pockets in the model, then the number of skipping steps is increased. For 1 time the machine loses approximately 0.3mm (0.012 ")
Im use Mach3mill post processor.
Im trying reduce Ramp feedrate up to 300mm/min and did not notice the changes.
Can you tell me what else can I try to change?
Replies (10)
daniel_lyall
Lower the acceleration and velocity in mach3, its not a fusion error it is in mach3.
The settings in mach3 will be letting it move faster that what it can realy do lowering them will keep the machine to a speed it can handle
What you can do in fusion is cut the lead in and lead out feed rate in half
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
thekondrat
I'll try to do it tomorrow.
When I use another CAM program, there are no such problems.
daniel_lyall
It's the speed change what does it is going from 0 to 1440 and back to 0 in 5 mm it's a impossibility so haveing this at a speed that it has a higher chances of hitting will always work better.
If you made it even faster the problem will get bigger
Daniel Lyall
The Big Boss
Mach3 User
thekondrat
I do not understand, what can i do to fix it?
daniel_lyall
Slowing down the lead in and out
Daniel Lyall
The Big Boss
Mach3 User
thekondrat
I reduced the acceleration along the Z axis from 450 to 150.
The result remained the same.
daniel_lyall
cut the velocity in half
Daniel Lyall
The Big Boss
Mach3 User
Did you ever find a fix to this issue? I have the same problem...
thekondrat
I tightened my end mill better.
My problem was that the cutter was pulled out of the collet during operation.
I think I figured out my problem as well. It was mainly my plunge feed rates and FRO speed. It was bottoming out and would skip when trying to pull it back up.
