Hello, is it possible to program this lathe: Style 510 (https://www.stylecncmachines.com/machines/style-510/) in Fusion 360? Can I use some build-in postprocessor?
Machine has saved programs made in machine computer with xxxx.CNT
But it can convert this files into (Iso files - .cnc) which can be opened in text editor, make some changes and import back to machine to run the program.
Thanks for help.
Thanks for help.
@mvolny2LUQ8 can you put a couple of sample files in a .zip folder and share them here to the forums? From that code, we should be able to point you in the proper direction as to which post processor might be a good starting point for you
Hello, here is the zip file with 2 programs, in 2 formats.
Thank you.
Thank you.
Hi there! So, I'd start with the mach3 turning post, as it's the simplest and will require the least amount of modifications. You can find it HERE
