Changing out a STEP file in an ongoing manufacturing operation
ebLARL2
ebLARL2
OK, so context first... Im programming a part to machine on my mill. A part I have in STEP format. A part that has been drawn in a different software. And to top it off, the STEP file (FileS) are saved as an assembly with the part in soft jaws, in a vice... An assembly drawn in another software.
So, when I decide that for whatever reason, I need to change out one of the step files for an updated one (Maybe we need to add a chamfer or radius or a better soft jaw... whatever), I simply can not... I must then create an entirely new manufacturing file and re select the surfaces and cutting paths and copy paste all of the setups and operations over from the older file.
I feel like I am burning an hour or two at a time to cure an issue easily and seamlessly done in other Softwares in minutes, by simply replacing the STEP file with a new one.
Can anyone help?
a.laasW8M6T
Hi
you can do this using the anycad workflow
https://help.autodesk.com/view/fusion360/ENU/?guid=ASM-INSERT-ANYCAD
You need to upload the  STEP file first in the web browser or use desktop conncector.
I prefer to use the web browser:
Then you can insert the STEP file(mine is a solidworks file in the image), into your document and it will maintain the link to the original file.
To update the STEP file you go to the web browser and re upload the STEP file.
now the document will show the linked file is out of date and you can update it without losing all the toolpath data etc
Christoph_360
Hello
I was also struggling with this problem recently until I found the solution with AnyCad.
Here I have made a sample video.
AnyCad.mp4
Video Player is loading.
Current Time 0:00
Duration 1:37
Loaded: 0.00%
Stream Type LIVE
Remaining Time 1:37
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Mfg
    Christoph
    ebLARL2
    great replies guys thanks... but when i update the step file... I still need to spend an hour re selecting surfaces and edges to make cut paths. so its still just the same as opening a new file and copy pasting over the old operations. or maybe im an idiot?
    a.laasW8M6T
    It should work out reasonably well, when I do it you normally have to just regenerate most of the toolpaths, but some will be broken due to the geometry no longer existing or some reference for the height has been changed etc.
    as long as you aren't making significant changes to the file there should be no problems
    I am doing this with solidworks files though, but in theory step files should work the same
    Christoph_360
    Hello
    With the help of this video I learned a lot about AnyCad.
    https://youtu.be/DnY0QLHsQiM
    Mfg
    Christoph
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
