Fusion Manufacture
problems with contour squaring up a block
3 REPLIES 3
cgr878
161 Views, 3 Replies
problems with contour squaring up a block / simulation looks good but tries to cut on only on side when I install on my tormach
3 REPLIES 3
jhackney1972
in reply to: cgr878
Please attach the model also.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
cgr878
in reply to: cgr878
Hopefully I did this right
jhackney1972
in reply to: cgr878
I really do not see why you need two toolpaths, I suppressed the 2D Contour and posted the 2D Adaptive toolpath and then ran it through a NC Simulator.  It seems OK to me.  Model is attached.
John Hackney
Retired
