Change Fixture # with Patterns?
I have a part I'm tipping at 15 deg and milling out a small pocket through. I have to rotate part 120 deg and repeat two more times.
I set this up using the pattern folder and set the pattern to circular. It generates the proper tool path, simulates perfect. The G-Code even looks perfect, except for our setup, I need each rotation to have it's own fixture number. I see I can override the number, but that changes the fixture number for the whole thing.
Is there a way to set this up so when it rotates, it assigns a new fixture number without me having to hand edit them?
