Change Fixture # with Patterns?
ARTHUR-HM
ARTHUR-HM
I have a part I'm tipping at 15 deg and milling out a small pocket through. I have to rotate part 120 deg and repeat two more times.
I set this up using the pattern folder and set the pattern to circular. It generates the proper tool path, simulates perfect. The G-Code even looks perfect, except for our setup, I need each rotation to have it's own fixture number. I see I can override the number, but that changes the fixture number for the whole thing.
Is there a way to set this up so when it rotates, it assigns a new fixture number without me having to hand edit them?
Steinwerks
Instead of a pattern, put them in folders and try override WCS, but you'll have to make a tool orientation for three separate toolpaths. Don't have time to create an example right now but this should work, if be a little tedious.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
ARTHUR-HM
This is what I normally do actually. I was just hoping that pattern would let me do it in a much faster manor. I think I'll add that to the ideastation. A little checkbox to increase fixture # per pattern instance would be super helpful.
LibertyMachine
I "think" there is one like that already on the HSM station. I'll try to find it
EDIT
Here it is
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
