What are the default chamfer supposed to be? Seems like the horizontal lead in rad has been set to 0mm and perpendicular is checked, also chamfer width is 0mm. These are the system defaults I get, not sure if I ever set user ones but something is different with update 2.0.18719 x86_64.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark
Mark Hughes
Those are the same values I get when I "reset to default". Is there an issue with this (as folks can change as needed)?
Well I guess fusion did a reset on the last update and overwrote my presets. I also noticed when creating setups my defaults had been overwritten as well. I always have stock offsets set to zero but after the last update they'd been reset to 1mm.
Just checked on another system and have the same problem. I always have these set to zero. Not had this happen for a long time, guess I should have saved my defaults.
Mark Hughes
Mark Hughes
