Usually I click edges or faces to orient the WCS to my needed situation. Since the update the WCS won't move properly. I can flip the directions and select a z surface, but it wont move the x or y.
No, I can't say that I've seen that behavior. Do you have a screen recording you can share?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
what do I use to make screencast recording? I thought they discontinued it?
I prefer to use ScreenPresso, others use OBS (which is open source and free). Yeah, we did discontinue the built-in recorder for a variety of reasons.
I had extruded a solid from an imported dxf file (from a customer). For some reason I couldn't change the orientation of the wcs. I started over--- instead of extruding the dxf, I projected the dxf onto another sketch within a new component and all worked as expected.
