Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Can i a create a milling prog and post for edm wire?
4 REPLIES 4
simon89EUJ
330 Views, 4 Replies
Hi
We have a fanuc edm wire machine with .25 wire and looking just to generate a toolpath from a model.
can i just set up a .25mm end mill and post out? then edit at the control for wire feeds etc?
anyone come up with a solution?
than
4 REPLIES 4
@simon89EUJ I would only use this if you are not using the U and V axis on the EDM wire machine. You could use the nc path generated for X and y axis and manually add you start and end parameters into the program not forgetting to add in your Z values if you have a driven Z.
If you machine with compensation,  G41 or G42 then the diameter of the tool you program with will not matter I do not think.
I would only use this for complex shapes.
If you have a lot of 2d standard shapes then I used to quickly achieve this by writing standard macros and then changing desired sizes.
Hope this helps.
Christopher Cooper
Technical Consultant
seth.madore
in reply to: simon89EUJ
I think @HughesTooling is running a 2D wire eroder using Fusion. Although, I seem to remember certain things getting changed in what is passed to the post that made this difficult. 🤔
Seth Madore
Share Wire EDM Feedback
I'm Fernanda, a Manufacturing specialist focused on the implementation of manufacturing solutions. At Autodesk we are always looking for ways to make our customers’ experience great.
We would love to hear your thoughts about Wire EDM.  Please respond to the following survey, which will help us to understand your current manufacturing needs. The survey should take 5 mins or less to complete.
Wire EDM survey link
We really appreciate your time. Your feedback helps make Autodesk even better.
matt.fame
I've done this many times for 2D wire cuts. I setup a .013" end mill 10" long. I had to edit the gcode afterwards to make it a wire program but it wasn't too bad. The answer I got for a post was NO! Again modifying the code wasn't bad so I never tried to make a post.
AHHH! I replied to a 4yr old thread. Dangit!
