I'm trying to CNC a part with a Torchmate 3.0 Mill Plasma. It's a simple 5 inch by 5 inch block, with a face, and 2D pockets cut into. I've set the WCS to the center (x,y), bottom (z) of the block, as well as other various points. No matter where I play the WCS, or set the CNC's origin to, I get the same error.
Toolpath goes outside of machine envelope by 3.099 inch in X
Toolpath goes outside of machine envelope by 3.099 inch in Y
And a similar message for Z with a different value.
No matter I zero the CNC's coordinates to, I get the same value for the error in X and Y.
Is this in fusion or torchmate.
What are your soft limits set to.
Is the WCS in fusion going to be at the same places on the machine.
