Fusion 360 2.0.16753 x86_64
Recently, the tool path names are being overwritten to all have the same name. Initially I thought this was only happening when duplicating setups, but this morning it just renamed all of my tool paths to the same name as the first operation, and I hadn't duplicated any setups. It even renames the setup to a tool path name. The only way to tell them apart is to look at the tool path icon.
I haven't been able to work out what trigger this yet.
This is a known bug that we think we've solved. Look for it to be fixed in a future update!
Sorry,
I did search the forum for this issue before posting, but obviously didn't use the correct search words as I didn't find anything.
In your defense, I think there's only been one or two posts on this topic, it's not surprising that you didn't find a thread. It's been a bit of a hot-topic in our internal channels, so it's all good 🙂
When is the fix for this coming? It may seem minor, but this is a real productivity killer.
We should have a fix for this in the next update 🤞
Hello! Any ideas when this update comes? Because this bug is very annoying. It also posts this NC program with the postprocessor and its very hard to see what is what now. Especially with the larger NC codes.
