BUG manual nc pass-through
Since the January 9th update I can no longer use pass-through manual nc: the dialog box appears but the box to type in the actual commands is gone.
Replies (21)
i have same problem after latest update, its a feature i used quite often too 😞
vzagainov
Same here, CAM passthrough commands are broken, glad I noticed that before feeding CAM program to my HAAS, otherwise could end up with the machine crash!!!
meckdie
Same here!
I HOPE I did not lose all the formulas that were in mine!!!!
Please fix this!!!
seth.madore
I am seeing the same. I'm checking with the team to see what they have to suggest
Seth Madore
jeff.pek
Issue acknowledged, CAM-12450.
This was supposed to be showing a (new) multi-line text box. Something obviously fell through the cracks in putting that in place.
We'll get an update out soon with a fix.
Jeff
jose.albertohehi
I editted my post so i can use the manual type "action" just like we used "pass-through" and it is working fine if you want i can add the part of my post for this to run.
KerryHarrison
Not only does pass through code not post but all the code previously entered using pass through is now gone in any file opened since the update.
This is a HUGE bummer!!!!!
lorenzoAFWU6
Yes please that would be useful to use action if it works instead of pass through.
jose.albertohehi
I added this my post and it works fine, be careful when you edit your post, every command you like to add on a new line separate them with a ", " (comma and space)
function onParameter(name, text){  //EDITED POST 11/01/2019
  if(name == "action"){
  var commands = String(text).split(", ");
  for (text in commands) {
  writeBlock(commands[text]);}
  return;
cirrus7-de
Still no real fix? Man this is getting urgent for us too now. We have to get parts done. And it will cost a lot of time and money to fix it by a workaround.
bobbyW3KYK
OMG, this has got to get fixed.  This is killing us we use this all the time for all our bar feeder and bar puller code........NOT COOL
seth.madore
@bobbyW3KYK
An update wen live less than an hour ago. This has been fixed. You will need to restart Fusion though for the download to come through
-EDIT- If you have opened and saved files containing Manual NC commands, give THIS  post a read
Seth Madore
bobbyW3KYK
I restarted and still no luck. Can I force it to update or something?
seth.madore
If you are connected to the internet and not behind an overly protective firewall (School, corporate IT, China) it should start downloading immediately.
Seth Madore
tomGKJVK
It appears this update has fixed it for my HAAS post, but not my FADAL post.   What do I need to do to get pass through working on fadal?   I have already updated to the latest Fadal post.
Hello all!
I'm still having issues with this bug. I'mtrying to add an M0 between different offsets so I can flip my part over between cuts. I have the manual NC action (STOP) after my last pass, but this is how my code is posting. I'm using the latest fusion update, and the latest UMC-750 post. Any help would be appreciated!! (also side question, are the N numbers for the lines of code inherent or is something wrong?)
how it is currently posting:
N6515 G49 (TCPC OFF)
N6520 M10
N6525 M12
N6530 M0
(Flip Part 180 Degrees about Y Axis)
N6535 M5
N6540 G53 G0 Z0.
How I want it to post:
N6520 M10
N6525 M12
N6530 M5
N6535 G53 G0 Z0.
N6540 M0
tomGKJVK
Ditto.  Same on Haas vf2 posts.   Ivecbeen manually editing programs to fix it, but would love it to post correctly.
daniel_lyall
@seth.madore  please, default posts need pass through added then saved to local or cloud post library???     https://knowledge.autodesk.com/support/hsm/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-use-M...
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
seth.madore
@daniel_lyall hmm? Are you saying that the AKN document fails to mention that you need to save this new post to a local or cloud folder, and not just over write the generic?
Seth Madore
