Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Bug in 2D pocket tool path generation?
3 REPLIES 3
fritter63
239 Views, 3 Replies
Video demonstrates what I'm seeing... can't see that I'm doing anything wrong.
3 REPLIES 3
LibertyMachine
in reply to: fritter63
No video attached yet
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
LibertyMachine
I suspect there is a direction arrow that you aren't seeing, as it might be hidden in the part. When you created the Setup, did you specify that body, or is it seeing another one in the setup?
If neither of these lead to a solution, could you share the part here? As it's not an assembly of linked components, File > Export > Save to local folder. Return to thread and attach your .f3d in your reply
Seth Madore
Steinwerks
I highly recommend not counting on the face selection to give you want consistently. Your best bet IMO is to select open contours for the geometry (think of this as the machining boundary) and then select the appropriate Stock Contours (sometimes isn't needed with appropriate contour geometry). Keep in mind that when you select faces the software is making its best guess in a "dumb" toolpath that is not model-aware. Sometimes this is affected by how the part is modeled even.
Edited to add an example:
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
