Best surface finish parameters for ballnose bits
jeffescott
Advisor Advisor
jeffescott
I need a long reach bit.  35 mm from holder to bit tip.   The hole is 5.5 mm id.
I would prefer a ballnose bit to provide best finish. On the counter sink and chamfers.
Should i use a 1/8 bit or a 3/16 bit
I generally i think both can provide a similar finish.  But the 3/16 would need a smaller step over. Step down with a stiffer shaft
Recomended parameters would be of great help as well
brad_francola
CNC_Lee
@jeffescott
I would go with the 3/16 ball endmill as a larger radii tool will always yield a better finish with a larger stepover. As far as speed and feed starting parameters, I have had great luck with the HSMAdvisor and FSWizard products for finding a good starting point and getting off in the right direction. You can also utilize a cusp height calculator like this:  http://cncprogramming.martinchick.com/ball_mill_finish.html to determine the estimated required stepover to achieve the desired surface finish.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
seth.madore
Here's another vote for the 3/16" tool, I always try to go with the biggest tool that is practical. That said, it would also be helpful to understand the application, so if you could share a screenshot or the actual file, you may find that our answer changes 🙂
Seth Madore
