Is there a way to have an arrange feature align wood textures to an axis?
see photo...
Solved by AmyLiu. Go to Solution.
1. can you upload the model?
2. Yes, you can arrange model as you want
3. some point you have to consider
- have enough room between two wood component if you planning for CNC mill
-If you planning for DXF file, use setup "cutting" when you use outpost you can have accurate DXF
Hi @kfleming4GCFS ,
The align is currently not supported, but it is on our list of future improvements for Arrange. keep you update. thanks for your attention.
yes, absolutely, Nesting workflow supports Orientation property(similar as Align), see
