Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Manufacture
Any reason why these toolpaths wouldn't generate?
3 REPLIES 3
FrodoLoggins
194 Views, 3 Replies
Used to generate very quickly:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
Hi FrodoLoggins
Could you share the project? Without the f3d it's impossible to tell what may be causing the problem.
Paolo
Paolo Bastianelli
Technical Consultant
Attached:
I tested it on my laptop and they all generate fine, quite quickly too. Not sure what could be causing it (but then again, we also have different OS's). Are you still having the same problem?
Paolo Bastianelli
