Hi - I have a body that has previously been turned and no its on the 5 axis. It has .063" radius channels running down it at 8 places. Back view
Side view
section analysis side view (to show slots)
The channel (and the body) start straight but then curve off at a 7" radius. Whats the best toolpath to use to follow that curve in the Z using a .125 ball mill ? Would that be trace ? (which I never use...) at the moment I'm just using a parallel toolpath
But for a lot of these things that's too time consuming.
thanks in advance !
Julian
Solved by seth.madore. Go to Solution.
Trace or Project would do the job. If you could share your file, we could apply some toolpaths to your part and see which gets you closest to a solution
Hi Seth - I'll give both a try, unfortunately I'm restricted on sharing the file due to client confidentiality.
Julian
Julian
Understood, it's not an uncommon restriction. If you could "save as" the part and defeature it, or create a sample file and share that, would that be possible?
ok I simplified the model to just the problem at hand, the first setup is a turning op (which in the original file has a dovetail etc) the second setup is the 5 axis one, currently I'm solving the problem with a 3+2 axis parallel toolpath.
Julian
Give this file a view. I've used the Project toolpath along with a surface offset and sketch to get you something that will machine a fair bit quicker:
Excellent, glad to hear!
