Adding a block delete to haas post.
ELAFING
Message 1 of 9
ELAFING
I want the coolant line to post as
/M8.
instead of
M8
when I simply add the / to the post it errors out.
Replies (8)
Message 2 of 9
Chetan.Bankar
Hi @ELAFING,
Thanks for raising your query onto Autodesk forum.
If I understand your query correctly it seems that you wish to avoid coolant code to output in the output G-code file?  If yes, then I will suggest setting the coolant to Disabled in the toolpath while generating. This will avoid generating M08 to be output in the G-code for that toolpath.
I hope this answers your query.
Thanks and Regards,
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 3 of 9
ELAFING
I want the coolant line to post.
With the haas control there is a block delete button on the control panel. Any blocks with "/" get skipped when the option is enabled. During dry runs I will enable it so coolant doesn't turn on. Then I disable it for actual runs.
I hope this clarifies what I am looking for.
Message 4 of 9
seth.madore
What post/machine do you have; Pre-NGC or NGC?
Seth Madore
Message 5 of 9
ELAFING
Pre
Message 6 of 9
ELAFING
Haas post, Pre-NGC
Message 7 of 9
seth.madore
Roger that. Sorry for the delay. There were some changes to the post syntax which made seemingly simple tasks such as adding a "/" a bit more complex.
Here's what you need to do:
1) Open up the Generic (OEM) Post Processor and do a "Save As". Save it to a local folder, not the Generic post library.
2) Go to line 2676 which should read: writeBlock(coolantCodes[c]);
3) Change that to: writeBlock(conditional((coolant != COOLANT_OFF), "/"), coolantCodes[c]);
Save.
Post.
Have Fun 🙂
Seth Madore
Message 8 of 9
zwelsh91
I have attached a post for early pre NGC HAAS, that I have edited for my 1990 VF-1. It has the block delete character where you want it.
Zak Welsh
Zakary Welsh Machine LLC
Message 9 of 9
ELAFING
Thank you both very much. Have a great day and I appreciate this community and all the help you provide.
