Hey guys having an issue I'd like to solve. I am running a Hurco VM1 Ultimax.
I run into issues machining when I am roughing with either 2d or 3d adaptive clearing. It seems when the tool path changes directions my machine pulses through the direction change and then takes off again through it's linear or radial path which is smooth. If I use contour the machine takes the entire tool path smoothly whith out any issues. It doesn't seem to change based on program or changes I make to the feeds, speeds, smoothing, or feed optimization parameters I change. I use the Hurco 3D post from the available Autodesk posts and have it set to basic NC.
I cut a lot of different materials using different tools and cutting parameters and it doesn't seem to matter. Anyone ever run into this issue or have a solution I haven't tried? Only thing I can think of is that it may be in the post, but that is over my head.
Look forward to hearing everyone's thoughts and solutions!
Solved by LibertyMachine. Go to Solution.
It seems the problem with the smoothing,
can you just share your model so that we can have a look at it
File>Export> .f3d
and reattach to this post
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
Please see the attached model and screenshots of my program settings. Like I mentioned above I've played around a lot with the smoothing settings, in different materials with different tools, feeds, speeds, and materials, and have never been able to fix this issue. Let me know what you think, as my understanding of how it works is not perfect.
It comes down to your Tolerance and Smoothing, and what works best for your machine. This is what you are seeing for points with your settings of .002" Tol. and .0002" Smoothing. Each one of these black points represents a new line of code:
This is what you would see with a .0005" and .001" tolerance:
Find what works best for your machines and the speeds you want to run. It's not a "one-size-fits-all" setting. I've settled on .0005" and .001" for my Mori and it works as well in my Kitamura. YMMV
Thank you man! I went in and plugged those parameters in today and it was almost silent.
