Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
5 Axis Post for non tcp controller - Toolholder length
2 REPLIES 2
infoR7QDP
468 Views, 2 Replies
Hello everyone,
We have a 5 axis machine that we have retrofitted with a chinese controller but unfortunately it does not support tcp for 5 axis machining.
We are using 5axismaker postprocessor and its working great but we have an issue since the machine has a tool changer with different holder.
The 5axismaker postprocessor take in to account only the toolbody and headoffset during 5 axis work but not the holder length.
headOffset = tool.bodyLength + pivotDistance;
This is the line in the post that creates the calculation how can we add the holder length to it?
2 REPLIES 2
serge.quiblier
in reply to: infoR7QDP
Hello @infoR7QDP
you can get inspiration from a piece of code from the rs274d multi axis post:
  // calculate the ABC angles and adjust the points for multi-axis operations
  // rotary heads may require the tool length be added to the pivot length
  // so we need to optimize each section individually
  if (machineConfiguration.isHeadConfiguration() && compensateToolLength) {
    for (var i = 0; i < getNumberOfSections(); ++i) {
      var section = getSection(i);
      if (section.isMultiAxis()) {
        machineConfiguration.setToolLength(section.getTool().overallLength); // define the tool length for head adjustments
        section.optimizeMachineAnglesByMachine(machineConfiguration, OPTIMIZE_AXIS);
  } else { // tables and rotary heads with TCP support can be optimized with a single call
    optimizeMachineAngles2(OPTIMIZE_AXIS);
This particular post, is recently the guinea pig for all improvement to the multiaxis code in our library.
It's the latest version of code we are testing, before trying to replicate on others posts.
regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
I have the same situation.  I run a head head machine and use 5axismaker PP   Everything works. However it would be even better if the post P could use tool offset length from my machine controller library not from fusion360  and just add that Height value to the pivot distance specified in my current PP setting ?   Is this possible in any way? Or with any Post processors ?   Any updates?
