Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
4th Axis toolpaths and new versions of Fusion 360
6 REPLIES 6
Smokeys
460 Views, 6 Replies
I'm thinking that 4th axis is the way to go here,  but I am not even sure on that.   It's a pretty small slice of 1 1/4 tube with parts cut out.   I tried looking through some YouTube video's but the options in Fusion have changed and left me kinda stuck.   Any hints on which way to go?    I am thinking I need the manufacturing extension, but before I go down that route want to make sure.   Picture and part attached.
6 REPLIES 6
a.laasW8M6T
in reply to: Smokeys
Hi
That's quite a tricky looking part to make
Have a look at the attached file for a rough Idea of how I would approach this part if I had to do it on a 4th axis.
Ideally I would mill the pocket in the end + the chamfer and then Wire edm everything else
Smokeys
I'm tempted to start a new topic as I am not sure if this is a bug or feature or what...    Anyways.   I figured out I could use round tube stock and just treat it like an 3 axis part.   But when I tried to do the setup of the mirrored part,  no way could I get the stock to work.
Smokeys
I forgot to add the fusion file.
a.laasW8M6T
That is odd, selecting that axis should work.
But I never bother creating a construction axis when you can just pick the cylindrical face of the outside of the part.
also, you keep mentioning Tube as the stock but you have it defined as a solid, why not define it as a tube?
Share Wire EDM Feedback
I'm Fernanda, a Manufacturing specialist focused on the implementation of manufacturing solutions. At Autodesk we are always looking for ways to make our customers’ experience great.
We would love to hear your thoughts about Wire EDM.  Please respond to the following survey, which will help us to understand your current manufacturing needs. The survey should take 5 mins or less to complete.
Wire EDM survey link
We really appreciate your time. Your feedback helps make Autodesk even better.
Fabbunny69
Depending on QTY I probably wouldn't go 4th Axis for this, just Jigs and Vice, 3 Axis.
I had a play, my file is attached.
