I am trying to to use 3D-contur, but instead of using a Stepdown I would like to use Stepover in the x-direction. So it is basically a scallop operation along the contour lines. Is there anyway to implement that? I attached the file, where I tried using a couple of different methods, but none of them is ideal.
Thank you for the help.
Solved by fredsi. Go to Solution.
Try a setup like this. Course Stepdown fine Stepover.
Mark Hughes
Owner, Hughes Tooling
Not sure how Maximum shallow Stepover works, setting it to 0.01 doesn't have much effect so maybe not as useful as I thought.
Mark Hughes
I can see why you would like the step-over capability, but don't think there is any way to implement. That said, I took profile you are trying to machine and broke it up into two contour operations using the 'Slope' setting in the geometry tab. That way, I was able to change the stepdown in one contour to a much lower number for the surface from 0-20deg (arbitrary choice) and get a finer 'step-over' in this area.
Fred
Contour is designed for more vertical wall and therefor it uses a stepdown, for more horizontal walls (or floors) we recommend using parallel.
Thank you for all the replies,
I will try the advice of fredsi.
@HughesTooling: I tried your approach before but did not get me good results
@jeff.walters parallel will not follow the contours but move only along x or y (at least in my understanding)
In Parallel you have an option to set the angle to whatever works best for you situation. But yes it won’t turn corners.
I saw that option, of using parallel and splitting deviding my part into 3 pieces, using different axes
I might still do this and compare the cut.
