I have some difficulty to use the 2d wrapped toolpath. The tool doesn't follow the curve of the surface or sometimes there is an error with empty toolpath.
How can I do correctly this 2d pocket ? 2d contour, 2d adaptive, flow, multi-axis ?
I have see the extend surface trick in a video but this doesn't really help.
Thanks for your advices.
Wrap isn't going to give you a perfect surface, it's going to violate either the floor or walls. Sadly, our true 4 axis offerings are extremely limited at present, but it's an area we are well aware of regarding what's lacking.
Ok but at Autodesk what is your best software to do this 4 or 5 axis task ?
