Fusion Manufacture
2D pocket continues to set z to 19.65
1 REPLY 1
lxr7RECN
136 Views, 1 Reply
I have a manufacturing progeam to run a 2D pocket.
My stock is 19.05 in height and 82mm by 82mm.
I tried every possible combination of stock height, stock origin in z axis, stock bottom, stock offset, selected point and whatever other option there is.
I even set the model itself to only 10mm. No matter what I try, it always generates g code which is trash and goes to 19,65. as if some idiot hard coded that number in Fusion.
I even created a brand new model, totally different, different height and all, again z is set to cut at 19.65.
1 REPLY 1
HughesTooling
in reply to: lxr7RECN
Can you share the f3d model here?
Mark
Mark Hughes
Owner, Hughes Tooling
