Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
2d engrave not following contour?
1 REPLY 1
thackelJ5EAP
100 Views, 1 Reply
I'm trying to engrave a fairly simple shape into a part. I'm using 2d engrave with a V bit selected, but instead of following the contours I've selected the machine is following along the outside and is offset by the width of the tool. There a setting I'm missing?
Sketch profile I'm trying to engraveSketch profile I'm trying to engraveToolpath being generatedToolpath being generated
1 REPLY 1
a.laasW8M6T
in reply to: thackelJ5EAP
the engrave toolpath is for "V-carving"
What you want to use is the 2D Trace toolpath if you want the tool center on the selected contours, use the Axial Offset to set the cut depth.
