Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
2d engrave feature selection problem.
8 REPLIES 8
Message 1 of 9
ElTejano
591 Views, 8 Replies
I am attempting to do use the 2d engraving feature on some brass but I am having problems selecting the edges. On some, it selects the loop no problem, but on others, it selects a different loop, like up and down and around. Is there any way to force this to chose the edges I need? It is with the most random features it chooses to let me pick or not. With text it is no prob normally. I did a few other designs that it did perfectly. Here is one design I was attempting to do today. On two of these, it let me select the loop no prob, the other two re some of the rest that didnt allow it. Any help would be greatly appreciated.19074909_10211701769637133_1491290720_o.jpg19095940_10211701768357101_1246178811_o.jpg19105124_10211701769837138_951651168_o.jpg19105143_10211701768037093_705794542_o.jpg
8 REPLIES 8
Message 2 of 9
daniel_lyall
in reply to: ElTejano
quite often just trying to select from a different spot work, when it's like that I just run the cursor around the contour to it finds the spot it can pick the top or bottom contour
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 9
Steinwerks
I actually helped someone out with a design much like this not very long ago and made a screencast:
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 9
ovisopa
In those cases I think it also helps to keep ALT pressed while you select the contour, and select each segment one by one, on the contour that wasn't correctly selected automatically.
Message 5 of 9
daniel_lyall
in reply to: ovisopa
@ovisopa you don't need to use Alt anymore they fixed that.
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 9
ovisopa
in reply to: daniel_lyall
So you only need to move along to that contour and it will show you automatically all the other different contours ?  I remember just a few weeks ago I had issues selecting and the only way I knew, was using ALT key, it did the job.
Now I reopened that model, and it had 7 chains before, I deleted all of them and selected again, it selected what I wanted, 2 chains only 🙂
Message 7 of 9
Steinwerks
@ovisopa
You're much better off editing the chain as I demonstrated in the screencast above. Otherwise you wind up with multiple chain segments and they don't always play nicely together.
Neal Stein
Find me on:
Message 8 of 9
ElTejano
in reply to: Steinwerks
Thank you so much for posting this. I dont understand why the program does not just chooses some edges correctly and not others. I will try this today.
Message 9 of 9
ElTejano
Just gave this a shot and it works excellent. Thank you very much for your help.
