Fusion Manufacture
2D Contour...where did multiple depths go?
2 REPLIES 2
dmealer
157 Views, 2 Replies
Hello all!
I am using 2d contour and need multiple depths.
The option seems to have disappeared.
See screenshot
2 REPLIES 2
seth.madore
in reply to: dmealer
The Multiple Depths option goes away when you select a Chamfer style tool. To achieve multiple depths, you will need to duplicate the toolpath and adjust your heights accordingly.
I don't like this limitation, but it's what's been in the product from the beginning 😞
I "think" you get different behavior if you use a Form tool or Tapered Endmill
Seth Madore
dmealer
in reply to: seth.madore
Thanks Seth. I picked a different tool and the option came back. I did not mean for the chamfer option to be on. Fusion did that because of the tool. I picked a flat face mill and the option returned. Sad our large face mill is also a chamfer mill but I guess you cant have everything.
Oddly enough using a facing toolpath with the same tool did not make the multiple depths option disappear.
Good things to remember moving forward.
Happy Holidays!!!!!!
Technology Administrators
