Fusion Manufacture
2D CONTOUR OPERATION CAN'T INTERPOLATE ARCS IN CAM OPERATION
2 REPLIES 2
ravidahiwala
238 Views, 2 Replies
In the Fusion 360 CAM environment, I see this frequently that 2D Operations (Contour, Bore etc) based off the Defined Geometry, Generated tool path is not an arc moves but 1-3 linear moves. Is there any setting in the toolpath to activate and generate arc moves?
tried changing Tolerance and Smoothing but nothing works.
https://a360.co/2ASm77v
Sincerely,
Ravi.
2 REPLIES 2
seth.madore
in reply to: ravidahiwala
The file you shared doesn't have any models in it, just a couple of sketches.
2D Adaptive does produce significant code, but I'm not seeing such an issue with the 2D Contour.
Seth Madore
ravidahiwala
in reply to: seth.madore
Thanks. I just figured out from " Multiple arc move" Forum Thread, Need to change Post Settings. e.g Minimum Chord Length etc. Arc moves are there but it just doesn't show when you simulate the tool path and check by show points.
after changing post settings, Got all correct output.
