2D Contour not following geometry properly
CuttingEdgeManufacturing
In the image below you can see the toolpath(with cutter comp on at the control) follows the geometry like it should until the radius get smaller. The tool is .25 and the radius is .26 so there really shouldnt be a problem there. obviously not the best scenario, but it should cut this toolpath right? at first i thought it was a setting i had set. so i did a 2d contour from scratch, added my tool and it gave the same results! Please help!
seth.madore
Compensation Radius Allowance on your Passes Tab. Set it to zero:
Seth Madore
Thanks!
i even looked over that setting and didnt think it would make a difference so i kept looking!
