2d Adaptive problems.
HughesTooling
Consultant Consultant
HughesTooling
Found a few problems with 2d adaptive.
First, I know it's only a roughing op but just for counterbores it's good enough unless you use a negative radial stock to leave.
No stock to leave looks good.
Negative stock not good. Stops short.
Next problem, why no maintain order for selected pockets?
And last why do I get a full retract between pockets and what's the warning about lifting the retract height to safe height if I set the retract too low? There doesn't seem to be a safe height I can set. File's attached.
Mark Hughes
Owner, Hughes Tooling
seth.madore
  1. I can get a ticket made for this issue, but I can't promise any action on it (it's a roughing path, afterall)
  2. I think we've fixed this internally
  3. I haven't looked at your file, but there is a hidden 2mm clearance that you can't adjust
Seth Madore
HughesTooling
Ok but what about the full retract between pockets? With the same selections 2d profile for example doesn't use the full retracted for moves between pockets\profiles.
Mark Hughes
