Y-axis toolpath problem
kalinkinandrei
kalinkinandrei
I have the following silly problem:
Most of the cutting of the below part I need done along the X-axis.
But the last fillet part (as I only have a flat bit atm) I would like to do along the Y axis.
For some reason I get toolpaths only for the X-Axis and I do not know how to change that.
Any help much appreciated and many thanks ahead.
Steinwerks
In the Passes tab change the Pass Direction to 90°. You can also use this to alter the direction from which the cut starts.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
kalinkinandrei
Thank you very much!
Just a minute ago actually by accident found the same solution on one of NYC CNC youtube videos.
