X/C posts in MM min, not degrees - Tool Breakage
Hi All,
I hope everyone is safe and well.
With the exception of a HAAS post, I would be having tool breakage issues with both Doosan and Mazak Mill/Turn Posts. They are posting X/C milling feed rates in MM/Min, rather Than Degrees Per Minute, which depending what diameter we care cutting at can overload the tool.
The HAAS post seems to vary the feed to allow for the DPM about the profile.
Does anyone have any Idea what I am doing wrong when using the Doosan/Mazak posts; I feel I'm missing something.
I've attached a photo of the code samples, both tools are programmed at the same cutting data for the tool, Which is a Cutting feed rate of 1909.86 mm/min, inside Fusion.
Thanks for reading, take care and stay safe.
