Wrapping Toolpath Feeds/Speeds
jeph_s22
jeph_s22
Good day everyone,
trying to make a brake on our mill/turn, see how it turns out.
I've posted two different screenshots of my NC code, one is when I wrap the toolpath, and the other is unwrapped. The wrapped toolpath feeds are crazy fast, and I am not sure how to fix this. I've attached the part for you to look at.
Can anyone give me any suggestions on how to fix it?
a.laasW8M6T
Hi
The Feeds look fast but actually aren't. When you have a combination of linear and rotary feeds they can look unusually large but that's because the post processor is doing a calculation of what the combined feed rate should be to get the actual desired movement on the machine, this is also why the feed is changing on every line.
If you actually run  it on the machine it should be fine.
There aren't any wrapped features on the part though, unless you were doing a chamfer on the slots?
Andrew Laas
Senior Machinist, Scott Automation
jeph_s22
Good morning, okay that makes sense then. I did a wrap tool-path on the slots for a different look.
One thing I didn't like when machining, is the machine would be very jerky - especially when it did the corners of the slots. Any advice on how to fix that? Also, when it moved from slot to slot, it would move in short increments instead of one continuous movement.
Looks to me my post processor needs a little help, any suggestions?
a.laasW8M6T
For The Jerkiness  on the rapid moves you can change the High feed rate in the linking tab to Always use High feed
As for the toolpath I'm not sure, it could be post related but it could just be the machines controller doesn't like code like that.
Andrew Laas
jeph_s22
Okay I will give it another go and try that. Thanks for your help!
