Why is it ignoring my fixture?
colinNPU8N
Message 1 of 22
colinNPU8N
I have a setup with part, billet and fixture, but when doing 3d adaptive, it still machines into the fixture? What am I doing wrong? Surely it can figure to go around the fixture and avoid? Or is this not implemented yet? I hope it is something I've missed.
Replies (21)
Message 2 of 22
ovisopa
I also though that selecting the fixture in setup will help in toolpath generation and avoid the fixture but it seems the fixture is only useful in simulation, you will notice the red lines in the timeline, while playing the simulation, that means the tool hit the fixture, or the material.
You should use the option AVOID/Touch surfaces if it's available for the operation you chose.
Message 3 of 22
colinNPU8N
@ovisopa thank you for the reply, I figured the collision in simulation, but thought it fairly self explanatory that selecting the fixture would mean it should avoid it too... obviously not!
3D adaptive doesn't have the avoid option which is odd; I'll have to use boundaries.
Message 4 of 22
al.whatmough
We do want to add avoidance of fixtures.
In the meantime, one workflow is to add the fixtures to the model override in your Adaptive operation.
Keep in mind, there is no option to add a clearance value.  So, you will need to model your fixtures larger by the amount of clearance you want.
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Message 5 of 22
Sq_14
Well i recently stumbled across the same problem and invested a LOt of time until i searche the net for an answer.
I thought, defining a fixture would make the program avoid it in tool path, but NO, i doesn't.
After reading this thread and seing the comment "we want to bring this in" back in may 2017, oh well ...
I'd suggest you change the "promising" caption of the 'fixture' field to something more explanatory like 'visualize fixture'
This alone would have helped a lot and saved some hours of time
Message 6 of 22
daniel_lyall
@Sq_14 it does work now you just add it to the model selection If you post your model so you can get help it would help you To attach a file Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 22
Sq_14
Hey, thanks for offering helping me out, but i already got the issue covered after reading this thread.
On the main subject, NO, it does NOT work, at least if you only  look at the naming of the section and the pop-up help you can get.
If you define a body as fixture, a 3D tool path will still plow right through it. If a 2D does this, well, this might be a case of model unawareness (aka dumb) tool path, but still !! this body is declared as a fixture and the tool should NEVER touch that body but stay away from it in any direction.
Adding faces, or probably the whole 'fixture' body to the model in the setup, well you gotta know, english is not my native tongue and it does not make sense at all, at least in my head, because the model is the part which i want to have subtracted out of defined stock. If i define my fixture as a part of my model, i really would define the fixture as a region that the tool should work on.
This is VERY counter-intuitive, at least in my head, and the caption and pop-up help does nothing to correct this line of thought at all.
Message 8 of 22
seth.madore
@Sq_14 you are correct, it's counter-intuitive and doesn't work as one would think. It's on the list of much needed improvements, and the developers are well aware of the need to improve this area. Sorry I don't have better info for you....
Seth Madore
Message 9 of 22
Fabbunny69
Hi, just found this thread after having similar issue to @Sq_14 , again after a few hours trying to work out why this function was not working ☹️
Accepting what @seth.madore  stated I would like to ask, at the moment does selecting a fixture do anything at all? Should the fixture show up in simulation so you could at least visually notice a tool touching it?
I also ask could you at least change the UI for this until it is operational?
Message 10 of 22
mattdlr89
@Fabbunny69 When you simulate it should tell you if your toolpath hits any of your fixtures defined in setup. The tool path generation will not take into account any fixtures. You may need to turn on the visibility of fixture in the browser tree when simulating if you want to see it. The visibility of fixture shouldn't effect any collision detection during simulation.
If you want your toolpath to avoid the fixture you can either add the fixture as a model body in your set up. Or if you want to do it on a per toolpath basic you can add select the fixture body (or faces of) in the model section under geometry.
Message 11 of 22
Fabbunny69
@mattdlr89 thanks for reply.
Now I know what it should do 👍 but for me the fixture I have selected is not showing up in simulation.
I think 'You may need to turn on the visibility of fixture in the browser tree' might have something to so with it, what do you mean by this? I have looked every where in browser tree and cant find this function.
Please forgive me if the solution to this is something really easy that I have missed!! 🤕
I attached my file in case that might help.
Message 12 of 22
mattdlr89
What I mean by turning on visibility is the eyeball symbol next to the body/component that is your fixture. When I opened your file and simulated it simulated with the fixture in place (I think) screenshots below.
Message 13 of 22
Fabbunny69
@mattdlr89 Got it. My understanding now is that the fixture selection in SETUP is purely to initiate collision detection, and selecting fixture in setup will not make it visible in simulation as is the case with your stock.
Your stock becomes visible once you are in simulation, no need to have your stock model visible in the browser tree but with your fixture you have to make it visible in the browser tree. 🤒
This seems a very convoluted way of doing it, @seth.madore  is there any reason why your fixture could not me made to be visible in simulation automatically, when you have a fixture selected? Why would you need to detect fixture collisions with out seeing your fixture?
FIXTURE SELECTED & FIXTURE MODEL VISIBLE IN BROWSER TREEFIXTURE SELECTED & FIXTURE MODEL VISIBLE IN BROWSER TREEFIXTURE SELECTED AND FIXTURE MODEL NOT VISIBLE IN BROWSER TREEFIXTURE SELECTED AND FIXTURE MODEL NOT VISIBLE IN BROWSER TREEFIXTURE NOT SELECTED AND FIXTURE MODEL SELECTED IN BROWSER TREEFIXTURE NOT SELECTED AND FIXTURE MODEL SELECTED IN BROWSER TREE
Message 14 of 22
mattdlr89
If you are not using a manufacturing model you can turn on "sync visibility with active setup" this will sort out all your visibilities automatically as you change between setups. This is located at the bottom of the screen in the middle. Unfortunately for now it is not compatible with the manufacturing model (the option will disappear when you create a manufacturing model if you are using them)
Message 15 of 22
Fabbunny69
Thanks, very useful information but I am not sure how this is useful to the fixture viability issues detailed previously, I will play with those sync settings tomorrow and try and work it out. Thanks again
Message 16 of 22
dgoller2RNYJ
Will Fusion 360 eventually learn to avoid the fixtures defined during processing of operations and keep toolpaths away from fixtures?
As far as I can see, it is still in the state of using it for simulation only, not for processing.
Best regards,
Daniel
Message 17 of 22
seth.madore
Yes, and we're actively working on that technology at the moment! Mind you, it's still a ways off from being released, but we've made some good progress in this area 🙂
Seth Madore
Message 18 of 22
Vohnsen
LMAO autodesk you are making yourself look foolish......
Message 19 of 22
shonut260
Observer
Observer
So here we are 2 years later and the issue is still not fixed! Can you offer up a date of when this will be fixed?
Message 20 of 22
seth.madore
I'm not exactly sure what it is you're referring to, as all of our 3D toolpaths are now completely model aware. 2D toolpaths are not, as they aren't even model aware (nor am I aware of any plans to make them so). Drilling, on the other hand, is now capable of collision detection.
You can find this functionality in two places:
1) You need to define your Fixtures in your Setup UI
2) All 3D toolpaths have the Touch/Avoid UI and allow for Machine, Avoid, Gouge or Fixture settings
Seth Madore
