Why can't "Shoulder Diameter" be edited?
UTD7ZNYB
UTD7ZNYB
When switching the tool type during the setup of tools with a Tool Shoulder, such as a dovetail mill or a slot mill, an error like the one in the image occurs. However, there is no place to edit the parameter. Editing via JSON and then loading it seems to work, but isn't it possible to make it editable directly from the tool library?
スクリーンショット 2025-06-18 092851.pngスクリーンショット 2025-06-18 092912.pngスクリーンショット 2025-06-18 093137.png
UTD7ZNYB
The diameter can be accepted even if it's 0.01 mm, but if it's 0, it results in an error. I will share the JSON file.
