Which 3D strategy for milling this?
m.van.hameren
Message 1 of 11
m.van.hameren
I've got this part pretty ready sofar, but I want to mill the highlighted area's with a 16mm ballmill. Can't find the proper strategy however. Please help, thanx in advance.
Mark.
Replies (10)
Message 2 of 11
ArjanDijk
Scallop and flow will both work. Flow depending on the surface quality. There was a video about machining a radius from autodesk.
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
Message 3 of 11
m.van.hameren
Can't get the right area's selected sofar.
Thanx for answering btw.
Message 4 of 11
ArjanDijk
Scallop with .2 stepover
Message 5 of 11
m.van.hameren
Thanks for answering again, Can it be done in this position too? I want to drill the 4 hole's and mill the 2 bigger holes in one operation??.
Message 6 of 11
ArjanDijk
You can, but you need a much longer tool and you will get vibrations in your material. The yellow marked pocket is from the same setup that I used.
Message 7 of 11
LibertyMachine
I was not able to get a clean toolpath out of Scallop, and I truthfully don't have enough practical experience with Pencil to do this justice. However, I DO know of a way where we can quickly accomplish one nice toolpath to clean things up:
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 8 of 11
ArjanDijk
Nice one, surface edit is a bit of work(and knowledge) but a nice way to handle this
Message 9 of 11
Marco.Takx
Hi @m.van.hameren,
The trick of @LibertyMachine is the best in my opinion.
But I always like to test if there are more options.
When you use the Beta mode for CAM you have the option for using the Blend operation.
This one is not as nice as @LibertyMachine but it creates almost the same toolpath.
The file is in the attachment.
2018-11-07_20-35-05.jpgIf my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 10 of 11
m.van.hameren
This was not quite what I meant, but thanx for the input!
Any handouts are welcome!!
Message 11 of 11
m.van.hameren
Thank you very much for this solution! Great!!
